Problem with java chat room use
blulou
Hi there
I have been having a problem for the last couple of days with staying connected in a chat room that is java.
I was in there and using it with no problems for a few weeks and then all of a sudden i started to get error messages and everytime I logged in i was getting disconnected and logged out again.
While I am in the chat room this message appears in the window:
internet connection having trouble attempting to clear it up please wait
Then after about 20 seconds I got this message and was logged off:
error receiving data from server read timed out
Then after a couple of tries getting in and getting logged out again, the message changed to this:
software caused connection abort
Everything else is working fine and my connection to the internet is fine. I am using a laptop wireless, so I went and checked the room on the main PC in our other room and the same thing is happening.
Other people in the rooms are having no issues.
I would be really great if someone could help me with this!!
Lou
Welcome to the Windows Forum.
What version of Java (JRE) are you using? The latest version is 1.6.0.17; if your version is older, uninstall anything older than 1.6.0.10, then download and install the latest version.
The next step I'd suggest is to open a Command Prompt window, and issue the following command
ipconfig /flushdns
then wait a few minutes, and try to connect again to the chat room.
P.S. if you still have problems after that, please specify your OS and browser.
Hey
Thanks for replying - I tried what you suggested above and it did not help.
Also I am wondering if it is something to do with my connection to the internet as there is a problem on the other pc.
My OS is Vista and I am using firefox - but I tried safari and that didnt work either. And the OS for my PC is XP.
Anyway any help or advice would be much appreciated.
thanks
Lou
Hi there
I am just wondering why it happened just in the last few days and not before?
And no they dont seem to be availlable for support.
It has been suggested to me that it could be my router and maybe a firewall that is blocking it, but when I have had a look there doesnt seem to be a firewall set up.
what do you think?
Thanks
Lou
It is sometimes the case that the site to which you are connected, or are trying connect to, is having problems for some reason. It has happened on this site several times. It is very often out of the control of the site itself.
If I were in your position I would just let sleeping dogs lie for a couple of days and then try again. You may do more harm than good by tinkering with things which do not need it.
"If it aint broke ...."
