raziiq Posted January 4, 2010 Report Share Posted January 4, 2010 Hi there.I am trying to make an app that launches a window(Form Window) whenever a user click a folder in Windows. My app will be running in the background all the time and it will be monitoring the double click of a particular folder.I have found thisFolder WatchBut the problem is that, it checks attributes of the folder instead of the double click.Is there anyway i can check the double click of a folder in Windows? Quote Link to comment Share on other sites More sharing options...
MANEMAN Posted January 4, 2010 Report Share Posted January 4, 2010 Hi there, You should have no problem doing what you want with : *AutoHotkey*, *Autoit* *BatchRunner* Quote Link to comment Share on other sites More sharing options...
