hatemhatem Posted March 11, 2010 Report Share Posted March 11, 2010 hello,i'm a newbie for teraterm and i have a problem to create my first macro :(my work consist to connect to my mobile via an usb cable and send an AT commands, when i type the AT commands i use data from my excel file; for example: AT%SLtype xxxxx, and xxxxx was found from an exel file, and these commands were all day the same and in the end when i type the AT commands i copy the results to my excel file. So i want to create a script or a macro ( or a Bat file) to do this job automaticly just the macro read data from excel file , send At command and in the end use result to copy them in my excel file :(((((((i want to know how can i do this ??? and what's the teraterm command i should use???and thxi started this topic here also : http://logmett.com/forum/viewtopic.php?f=3&t=1337 Quote Link to comment Share on other sites More sharing options...
Boris Posted March 11, 2010 Report Share Posted March 11, 2010 Have you looked in the manual ?/>http://ttssh2.sourceforge.jp/manual/en/ Quote Link to comment Share on other sites More sharing options...
hatemhatem Posted March 11, 2010 Author Report Share Posted March 11, 2010 Yes but i don't find anything :( Quote Link to comment Share on other sites More sharing options...
Boris Posted March 11, 2010 Report Share Posted March 11, 2010 It is unlikely that any of our regulars have used this. I have never heard of Teraterm until today. Do they have a User Forum for you to try ? Quote Link to comment Share on other sites More sharing options...
Boris Posted March 11, 2010 Report Share Posted March 11, 2010 Ah! - you have already asked them :) I had not realised.The support forum is maintanced by Boris Maisuradze. This forum is English only./>http://logmett.com/forum/ Quote Link to comment Share on other sites More sharing options...
hatemhatem Posted March 11, 2010 Author Report Share Posted March 11, 2010 yes i have asked them but no response :s what should i do?? Quote Link to comment Share on other sites More sharing options...
Boris Posted March 11, 2010 Report Share Posted March 11, 2010 My advice is to be patient and wait for someone there to respond :) Quote Link to comment Share on other sites More sharing options...
hatemhatem Posted March 11, 2010 Author Report Share Posted March 11, 2010 OK Boris and Thx :) hope is not dead ;) Quote Link to comment Share on other sites More sharing options...
