how block port 21
maisun
Start Menu -> Local Area Connection > properties
item -> Properties button >Tcp/IP > properties > Advanced -> options,
Tcp IP Filtering is in the list, highlite/select it
Beneath the Optional Settings, press/click the properties button on the lower right-hand side
Check the "Enable Tcp/IP Filtering"
There you choose which ports you want to block
this is for XP
vista and 7 should be similar
