About Chinese fonts
Usually it's not a font problem since CJK scripts are different from alphabetic ones
Most likely you will need to do this:
1. Click Start > Control Panel. Select the Date, Time, Regional and Language Options category, then click Regional and Language Options.
2. On the Languages tab, select the checkbox labeled Install files for East Asian languages.
3. Click OK when a dialog box appears informing you of the storage requirements for the language files (230 MB).
4. Click OK on the Languages tab.
5. Another dialog box appears requesting a Windows XP installation disk or network share location where the language support files are located. Insert a Windows XP installation CD or browse to the appropriate network location, and click OK. Microsoft Windows installs the necessary files and prompts for you to restart the computer.
6. Click Yes to restart the computer.
Hi Seshomaru,
Lot of thanks for your detail advice. I got it done. Now leaving behind is antivirus problem.
B.R.
satimis
