DevixLuvic Posted June 27, 2010 Report Share Posted June 27, 2010 Hey all,I have decided to give an older laptop to my friend. It was using Windows XP, but it was very slow. I re-installed Windows 98SE on it, and then set up basic functionality. Now I want to have internet, which is a problem, as it does not have a ethernet port built in. I would like to use a DLink WNA 1330 card with it, but it has errors with the driver. I will record those errors and post them later, if you need them.I have a device that plugs into the printer port for ethernet, would that be useful at all?-Devix Quote Link to comment Share on other sites More sharing options...
-pops- Posted June 27, 2010 Report Share Posted June 27, 2010 Where have you looked for drivers? A Google search may come up with something more suitable than the one you have already e.g. http://download.cnet.com/D-Link-WNA-1330-Notebook-Adapter/3000-2112_4-90583.html Quote Link to comment Share on other sites More sharing options...
crovax85 Posted July 8, 2010 Report Share Posted July 8, 2010 make sure you have the right drivers for the card. and make sure they are compatible with Win 98. Quote Link to comment Share on other sites More sharing options...
