Task scheduler problem
Hello,
i have a little problem with the Task scheduler on Windows 7.
I would like to use it to start a program, while my PC is at hibernation through the nighttime, so it can run while i am not at the PC.
The problem is, that when i plan the Task in the Scheduler, my PC will start at the time i choose and wake up from the hibernation, but it all get stuck at the User logon screen.
I tried filling up both possibilities in the Security tab (Run only when user is logged on and Run whetever user is logged on or not), then it askes for my passwort and i fill it in. But it gets still stuck at the User logon screen after waking up the PC and wants the password to type in.
Please, can someone help me? I have only one account set up as the administrator with password, nothing else. Why won´t it just work
I know of auto logon, it would solve it, but it´s not an option. The computer needs to have a password.
It clearly says in the instructions:
"In the Users tab, uncheck the box next to Users must enter a user name and password to use this computer."
John.
John.
I can not find any checkbox like that, i have Windows 7 btw, not XP:
Anyways, i already solved my problem, it was in power management and the tickbox Request password after start-up from hibernation.
Notw i got another problem: after i plan a program start up in Scheduler, it wakes up the PC, logs in, but won´t launch the program. I tried setting up RapgetRS, Image Viewer, Irfan View, tons of others and it won´t launch even one of them.
But you just came back to say thanks for our help. - That's decent of you.
P.S. We will make sure nobody clicks on that crap link you put in.
Bye............... Missing you already. :)
John.
