Problem with icons
jmaster18
Something crazy has happened to me as I opened my computer today.I opened a folder in my desktop in which I have my games shortucts.All shortcuts had changed icons.Not the usual icon of an application which usually happens and alla I need to do is to change icon.One of my games had the icon of a hard disk another game had the icon of install shield wizard and another the icon of my documents folder.Lookgamesi.jpg.I tried to change icon on each files properties but it didnt work.And then I realised that not only the shortcuts but the original files on each game folder had also changed appearence. I believe it is a registry problem but i dont know what to do to fix it.does anyone knows??Thanks in advance.
I thimk I found what is causing this problem but I dont have permenent solution. When I run a certain application(FIFA WORLD CUP 2010 PATCH) which has a lot of bugs and crashes to desktop I experience this problem.What I have to do then is to get its shortcus out of the folder with the other games,then change the icon size and then restart.After all this the icons are correct.I dont know if the problem occurs again.I tried all this after a system restore of course so thanks.
