SIDE BY SIDE CONFIGURATION ERRORS
Retep
TOSHIBA A300-1bz 3GB RAM 250 GB hdd running Vista home premium with SP2
My wife's laptop will not run many installed programs because of "side by side configuration errors". I have tried all the "fixes" that I found on the web but nothing has worked. The laptop even totally ignores some administrator command prompt intructions. I have given up trying to cure this.
My question -- will upgrading from "Vista 32 bit SP2" to Windows 7 solve this and let her programs run again?
I suspect you may have some infection on your machine.
In stead of spending many fruitless hours trying to patch it up, I would do a format and fresh install of Windows.
Upgrading may not work very well if you are intending to put the upgrade over the existing (faulty) configuration. It just may happen that whatever is causing the problem will transfer on to the new install.
Thanks -pops- If I do that and have copied my program and data files onto an external HD would it be OK to copy them back after a "clean" install of windows 7?
It is very difficult, almost impossible to transfer programs from one operating system to another - one reason being that Windows distributes bits of programs all over the place and it is not feasible to collate these.
Data recovery should be OK but be very careful in virus/malware detection before loading.
