TheCreeL Posted December 3, 2010 Report Share Posted December 3, 2010 Hello everyone, I got an Acer aspire 5745G with double GPU (intel and nVidia),i found that if you change from "switchable" to "discrete",in windows there's a problem with the cards... [under switchable everythig ok, but under discrete resolution blow up]... so i decided to install nVidia drivers under discrete too... Just now i found that doing so under switchable mode, resolution and switch application [to change from nVidia GPU to intel one] are gone...how could i get the switchable mode working again as before?Thx =) Quote Link to comment Share on other sites More sharing options...
Boris Posted December 3, 2010 Report Share Posted December 3, 2010 Is this the model where you switch by pressing the P key above the keyboard ?Have you tried a System Restore back to before where you started "playing" with it ? Quote Link to comment Share on other sites More sharing options...
TheCreeL Posted December 3, 2010 Author Report Share Posted December 3, 2010 Is this the model where you switch by pressing the P key above the keyboard ?Have you tried a System Restore back to before where you started "playing" with it ?nope i switch using an icon in the bottom right bar,no i dont, because i already had some not too old Quote Link to comment Share on other sites More sharing options...
Boris Posted December 3, 2010 Report Share Posted December 3, 2010 Is this the model where you switch by pressing the P key above the keyboard ?nope i switch using an icon in the bottom right bar,Do you have this button on your laptop (on right hand side at top) ? If so have you tried it ? Quote Link to comment Share on other sites More sharing options...
TheCreeL Posted December 4, 2010 Author Report Share Posted December 4, 2010 Yeah, i got it but when i press it , a window pop up saying that you are changing from performance mode to powersaving mode, but when i do it nothing happened on the screen Quote Link to comment Share on other sites More sharing options...
