vanhove14 Posted January 4, 2011 Report Share Posted January 4, 2011 I have a linksys internet modem. It has not been working great here lateley. It will only load about 50% of the websites I try to visit. I have tried restarting it and it only works for a short time. Does anyone have any ideas as to why the modem will load half of the websites I visit and not be able to load the other half while still showing that it is connected to the internet. Quote Link to comment Share on other sites More sharing options...
MANEMAN Posted January 4, 2011 Report Share Posted January 4, 2011 You haven't filled out your profile, so we have no idea where you live. It has not been working great here lateley If you reside in China, unfortunately you are experiencing "The Norm". Other than that, check with your ISP to make sure that they have not started blocking certain sites in your country. I have a linksys internet modem. You haven't told us the model ! We cant really do any decent diagnosis or give views.Check the Router/Modem Firewall settings.Try another Router/Modem.Check all wiring from telephone line to modem.You haven't really given us much information to work with.John. Quote Link to comment Share on other sites More sharing options...
F Reed Posted January 24, 2011 Report Share Posted January 24, 2011 I personally don't rate entry level Linksys kit at all, and would suggest trying a different modem Quote Link to comment Share on other sites More sharing options...
MANEMAN Posted January 24, 2011 Report Share Posted January 24, 2011 F REED Said: I personally don't rate entry level Linksys kit at all, and would suggest trying a different modem I had already said that in the post previous to yours. "Check the Router/Modem Firewall settings.""Try another Router/Modem."What exactly do you mean by "Entry Level ?"How have you ascertained that "Entry Level" equipment is being used ?John. Quote Link to comment Share on other sites More sharing options...
