PosingOwl Posted January 30, 2011 Report Share Posted January 30, 2011 Ok, i been having problems installing Ubuntu.... I have this....Disk deva/sda :160.0Gb / 160041885696 bytes255 heads, 63 sectors / track, 19457 cylindersunits = cylinders of 16065 * 512 = 8225280 bytesSector size (logical/physical) : 512 bytes / 512 bytesI/O size (minimal/optimal) : 512 bytes / 512 bytesDisk Identifier : 0x06de873fDevice Boot Start End Blocks ID System/dev/sda1 * 1 8437 67770010 7 HPFS NTFS/dev/sda2 8438 / 19548 / 88519681 / 5 / ExtendedThats It, last line I kinda got confused were they go...Now I am getting an root error when I am at the partition page.....Thanks, Donald Quote Link to comment Share on other sites More sharing options...
Alan2273 Posted January 30, 2011 Report Share Posted January 30, 2011 Is this an install using the entire disk, or are you manually editing the partitions?. Quote Link to comment Share on other sites More sharing options...
PosingOwl Posted January 31, 2011 Author Report Share Posted January 31, 2011 I used Wubi to insatll it.... Everything is working now.... But yes I was manually editing the partitions, which I never should have done.... Quote Link to comment Share on other sites More sharing options...
Alan2273 Posted January 31, 2011 Report Share Posted January 31, 2011 Glad you sorted it.WUBI can be uninstalled through add & remove programs. Quote Link to comment Share on other sites More sharing options...
