Autorun problem.
I bought a used Dell XP60 computer early last month. The Autorun worked at first, but eight days ago it stopped working. How should I correct this problem?
Open Windows Explorer by pressing the Windows + "e" key.
Right-click the desired CD-ROM and select Properties from the menu.
Select the AutoPlay tab.
Select each item from the pulldown list and for the Action to perform, select "Take no action" to disable autorun, or pick the apporpriate action to take if enabling autorun.
Select OK.
