Yugesh Posted March 14, 2011 Report Share Posted March 14, 2011 hi i'm trying to install ns-allinone-2.29.2.tar in windows 7 by using cygwin installer..At the starting i got this message============================================================* Testing for Cygwin environment============================================================Cygwin detectedNote: Cygwin install is still considered EXPERIMENTALChecking Cygwin version is >= 1.3.12... 1.7.8 (should be ok)Checking filesystems are mounted as UNIX filetype... yesChecking default mode is binmode... yesChecking legitimate login name... okChecking legitimate path name... okChecking for gcc... okChecking for gcc-g++... okChecking for gawk... okChecking for tar... okChecking for gzip... okChecking for make... okChecking for patch... okChecking for perl... okChecking for w32api... okChecking for diff... okChecking for X... None found!Neither Package xorg-x11-base nor XFree86-base is present on your system.Please install one of it using Cygwin's setup.exebefore trying to install the ns-2 distribution.The above test indicates that your installation of Cygwinis probably NOT SUITABLE for installing ns-2 allinone.(More details can be found in the specific error message above.)Do you wish to proceed regardless? [y/N]After continuing i got error messageIn file included from trace/trace.cc:42:./sctp/sctp.h: At global scope:./sctp/sctp.h:65: warning: `typedef' was ignored in this declaration./sctp/sctp.h:78: warning: `typedef' was ignored in this declaration./sctp/sctp.h:85: warning: `typedef' was ignored in this declaration./sctp/sctp.h:95: warning: `typedef' was ignored in this declaration./sctp/sctp.h:104: warning: `typedef' was ignored in this declaration./sctp/sctp.h:135: warning: `typedef' was ignored in this declaration./sctp/sctp.h:150: warning: `typedef' was ignored in this declaration./sctp/sctp.h:162: warning: `typedef' was ignored in this declaration./sctp/sctp.h:191: warning: `typedef' was ignored in this declaration./sctp/sctp.h:203: warning: `typedef' was ignored in this declaration./sctp/sctp.h:209: warning: `typedef' was ignored in this declaration./sctp/sctp.h:221: warning: `typedef' was ignored in this declaration./sctp/sctp.h:229: warning: `typedef' was ignored in this declaration./sctp/sctp.h:241: warning: `typedef' was ignored in this declaration./sctp/sctp.h:262: warning: `typedef' was ignored in this declaration./sctp/sctp.h:268: warning: `typedef' was ignored in this declaration./sctp/sctp.h:273: warning: `typedef' was ignored in this declaration./sctp/sctp.h:280: warning: `typedef' was ignored in this declaration./sctp/sctp.h:282: warning: `typedef' was ignored in this declaration./sctp/sctp.h:291: warning: `typedef' was ignored in this declaration./sctp/sctp.h:306: warning: `typedef' was ignored in this declaration./sctp/sctp.h:425: warning: `typedef' was ignored in this declaration./sctp/sctp.h:431: warning: `typedef' was ignored in this declaration./sctp/sctp.h:443: warning: `typedef' was ignored in this declaration./sctp/sctp.h:451: warning: `typedef' was ignored in this declaration./sctp/sctp.h:458: warning: `typedef' was ignored in this declaration./sctp/sctp.h:460: warning: `typedef' was ignored in this declaration./sctp/sctp.h:510: warning: `typedef' was ignored in this declaration./sctp/sctp.h:516: warning: `typedef' was ignored in this declaration./sctp/sctp.h:527: warning: `typedef' was ignored in this declaration./sctp/sctp.h:534: warning: `typedef' was ignored in this declaration./sctp/sctp.h:553: warning: `typedef' was ignored in this declaration./sctp/sctp.h:558: warning: `typedef' was ignored in this declaration./sctp/sctp.h:564: warning: `typedef' was ignored in this declaration./sctp/sctp.h:571: warning: `typedef' was ignored in this declaration./sctp/sctp.h:577: warning: `typedef' was ignored in this declaration./sctp/sctp.h:705: error: extra qualification `SctpAgent::' on member `DumpSendBuffer'trace/trace.cc:185: warning: deprecated conversion from string constant to `char*'trace/trace.cc:185: warning: deprecated conversion from string constant to `char*'trace/trace.cc:185: warning: deprecated conversion from string constant to `char*'trace/trace.cc:185: warning: deprecated conversion from string constant to `char*'trace/trace.cc:185: warning: deprecated conversion from string constant to `char*'make: *** [trace/trace.o] Error 1Ns make failed!See http://www.isi.edu/nsnam/ns/ns-problems.html for problemsAnybody can help to install it properly..Urgent..Please help. Quote Link to comment Share on other sites More sharing options...
Boris Posted March 14, 2011 Report Share Posted March 14, 2011 NS2 is only shown as working under XP2 (SP2) and older O/S with Cygwin - so it possibly isn't compatible with Windows 7 ?/>http://nsnam.isi.edu/nsnam/index.php/Running_Ns_and_Nam_Under_Windows_9x/2000/XP_Using_Cygwin Quote Link to comment Share on other sites More sharing options...
Boris Posted March 14, 2011 Report Share Posted March 14, 2011 Read all this ? :-/>http://paulson.in/?p=49 Quote Link to comment Share on other sites More sharing options...
