Nyxm Posted March 25, 2011 Report Share Posted March 25, 2011 Hello everyone. I recently received an old Dell Latitude that had XP Prof on it. It previously belonged to a manufacturing company, so I used a XP SP2 re-installation CD to start from scratch. The only problem is that my other laptop was already working fine with WPA encryption with my router and the only kind I can get XP to use is WEP. I have done all the updates that I can find and now have SP3 for XP. I tried to just use WEP, but with 7, it asked me for a user name and password and I don't know what to put in that field. If someone could help me get either WEP working on 7 or WPA working on XP, I would really appreciate it. I have WIndows XP Professional Version 5.1(Build 2600.xpsp_sp3_gdr.101209-1647 : Service Pack 3) on my Dell and Windows 7 Ultimate Version 6.1 (Build 7601 : Service Pack 1) on a Compaq. I just updated both before I posted this. Thanks for the time that anyone who reads this is spending. Quote Link to comment Share on other sites More sharing options...
Boris Posted March 26, 2011 Report Share Posted March 26, 2011 What model Latitude is it ? Quote Link to comment Share on other sites More sharing options...
Nyxm Posted March 26, 2011 Author Report Share Posted March 26, 2011 What model Latitude is it ?It is a Latitude C640 and the model # is PP01L. Quote Link to comment Share on other sites More sharing options...
Boris Posted March 26, 2011 Report Share Posted March 26, 2011 If you are using its built-in wireless capability, have you installed the latest wireless driver for it from :-/>http://support.euro.dell.com/support/downloads/driverslist.aspx?c=uk&cs=ukbsdt1&l=en&s=bsd&ServiceTag=&SystemID=LAT_PNT_P4N_C640&os=WW1&osl=en&catid=&impid= Quote Link to comment Share on other sites More sharing options...
Nyxm Posted March 26, 2011 Author Report Share Posted March 26, 2011 If you are using its built-in wireless capability, have you installed the latest wireless driver for it from :-/>http://support.euro.dell.com/support/downloads/driverslist.aspx?c=uk&cs=ukbsdt1&l=en&s=bsd&ServiceTag=&SystemID=LAT_PNT_P4N_C640&os=WW1&osl=en&catid=&impid=Now that I have updated the drivers, I can select WPA-PSK, but it won't connect. Perhaps my router isn't set up to handle TKIP (whatever that is). I'll check and post back. Quote Link to comment Share on other sites More sharing options...
Nyxm Posted March 26, 2011 Author Report Share Posted March 26, 2011 The router seems to be set to the same kind of encryption that I now have my Dell set for, but I still cannot get it to connect to an encrypted network. Of course, I have no trouble with unsecured networks, but I don't want to leave my network without any password safety. Quote Link to comment Share on other sites More sharing options...
Boris Posted March 26, 2011 Report Share Posted March 26, 2011 What model of router is it ? Quote Link to comment Share on other sites More sharing options...
Nyxm Posted March 26, 2011 Author Report Share Posted March 26, 2011 What model of router is it ?It is a Netgear WGR614 v8. Quote Link to comment Share on other sites More sharing options...
Boris Posted March 27, 2011 Report Share Posted March 27, 2011 Well - that should be able to support WPA-PSK according to the manual Which mode is it set to ?g & bg onlyb onlyIs your Latitude b or g ? Quote Link to comment Share on other sites More sharing options...
Nyxm Posted March 27, 2011 Author Report Share Posted March 27, 2011 Well - that should be able to support WPA-PSK according to the manual Which mode is it set to ?g & bg onlyb onlyIs your Latitude b or g ?The router is set to g & b, but I don't know how to find out how the Dell is set. Quote Link to comment Share on other sites More sharing options...
Boris Posted March 27, 2011 Report Share Posted March 27, 2011 Change the setting to "g only" to see if that makes a difference ?Don't bother - it won't :( see below Quote Link to comment Share on other sites More sharing options...
Boris Posted March 27, 2011 Report Share Posted March 27, 2011 According to this :-/>http://www.dell.com/downloads/us/products/latit/c640_spec.pdfyour model only supports "b"- which I think means it only understands WEP Quote Link to comment Share on other sites More sharing options...
Boris Posted March 27, 2011 Report Share Posted March 27, 2011 I think that the Latitude is a bit short of USB ports ???So, probably, the simplest and cheapest solution would be to get one of these for it :-(wireless networking PC card for laptop to use the 802.11g standard)/>http://www.amazon.com/Cisco-Linksys-WPC54G-Wireless-G-Notebook-Adapter/dp/B00007KDVK- which would then give it "g" capability. Quote Link to comment Share on other sites More sharing options...
Nyxm Posted March 27, 2011 Author Report Share Posted March 27, 2011 I think that the Latitude is a bit short of USB ports ???So, probably, the simplest and cheapest solution would be to get one of these for it :-(wireless networking PC card for laptop to use the 802.11g standard)/>http://www.amazon.com/Cisco-Linksys-WPC54G-Wireless-G-Notebook-Adapter/dp/B00007KDVK- which would then give it "g" capability.Yeah, I only have one USB on the back and sideways from what you would normally see. I think that I will try the wireless card. Thanks for all your help! Quote Link to comment Share on other sites More sharing options...
Boris Posted March 27, 2011 Report Share Posted March 27, 2011 Thanks :)Let us know how you get on. Quote Link to comment Share on other sites More sharing options...
