ToberG Posted March 26, 2011 Report Share Posted March 26, 2011 Hey everyone,i had Windows 7 x64 SP 1 and i think my USB Mass Storage Device is broke,i think because i don't safely remove device.Now when i try safely remove device it's says that other stuff using that device,or just give my Don't Send.And when USB Mass Storage Device is Enabled My Computer start lagging C/D drives opening in 2-3 min'sWhen Disable everythink ok.I try uninstal USB Mass Storage Device,but affter Restar same problem.So please help me :) I think it's be best to re-instal USB Mass Storage Device,but i can't find on W7 x64 Quote Link to comment Share on other sites More sharing options...
bludgard Posted March 27, 2011 Report Share Posted March 27, 2011 And when USB Mass Storage Device is Enabled My Computer start lagging C/D drives opening in 2-3 min'sHigh, ToberG.Welcome to Windows Forum.Are you able to post screen shots of this behaviour as well as disk management with the mass storage device included? Use the "Click To Attach Files" button below the full editing post options.Sometimes I will have an external hard drive or memory device with several partitions connected and if I don't eject the "disk" that I am working on before using "Safely Remove Hardware" I will get the same behaviour. This may not be your issue. That Is why I suggested the images. There could be several reasons for what you have going on. There are some options available if it is a corruption issue. However, I would suggest you back up whatever you deem valuable before trying anything. If you care to continue this witch hunt, the ball is in your court.One Quote Link to comment Share on other sites More sharing options...
