sims 2 lagging. can someone help?
when i play the sims 2 my computer lags so much it is unplayable even though my computer meets the system requirements. can someone help me?
sims 2 system requirements:
  • 800 MHz processor or better
  • 256 MB RAM if Windows Vista, XP, Windows ME, Windows 98 or Windows 2000
  • At least 3.5 GB of hard drive space
my computer has:
3gb ram
ati radion hd 3600 AGP with 1GB of video ram
2.4 GHz Pentium 4
Intel D865PERL motherboard
Samsung sv8004h 80gb IDE hard drive(main hard drive)
Fujitsu MHY2120BH 2.5 inch SATA hard drive (unformatted )
OS Name Microsoft Windows XP Home Edition
Version 5.1.2600 Service Pack 3 Build 2600
OS Manufacturer Microsoft Corporation
System Name MONSTROSITY
System Manufacturer INTEL_
System Model D865PERL
System Type X86-based PC
Processor x86 Family 15 Model 2 Stepping 7 GenuineIntel ~2394 Mhz
BIOS Version/Date Intel Corp. RL86510A.86A.0089.P21.0502132202, 2/13/2005
SMBIOS Version 2.3
Windows Directory C:\WINDOWS
System Directory C:\WINDOWS\system32
Boot Device \Device\HarddiskVolume1
Hardware Abstraction Layer Version = "5.1.2600.5512 (xpsp.080413-2111)"
Total Physical Memory 3,072.00 MB
Available Physical Memory 2.46 GB
Total Virtual Memory 2.00 GB
Available Virtual Memory 1.96 GB
Page File Space 4.84 GB
Page File C:\pagefile.sys
you could have a look in Task Manager to see what is using up processor time while the game is running - press Ctrl-Alt-Del, go to task manager and then go to the processes tab and see what is going on with CPU. Or, if you don't get on with that, download Process Explorer from Sysinternals and run that while the game is on noting which processes are monopolising processor time. You could also go to administrative tools and take a look in Event Viewer to see if there are any current events related to the game. Also, when you first start the game and the welcome screen comes up ( if it does - I can't recall now if you get a discrete window to click on to start from or if the game starts immediatly), bring up task manager ( ctrl-alt-del), go to the processes tab, scroll down and highlight, then kill explorer.exe. Keep the task manager window up if it hides behind the game as you will need to use it again when you finish playing to get your desktop and taskbar back. Otherwise you will need to do the three keys again to bring it up. When you have finished the game you need to go into Task Manager again and go to Application tab, click on New Task and then type explorer.exe in the box and apply or OK, and that will bring the desktop icons and taskbar back. If you can shut down your AV while you are gaming that can help as well. If none of that works, you could try reinstalling the game again. Hope this helps.
