A drive in RAIDO volume is failing???
Winging
First of all, check that your cables (power and data) are firmly connected at both drive and motherboard ends, to see if that cures anything.
Also you could try a chkdsk c: /f in cmd prompt and tell it to run the next time Windows starts.
This will check your disks' filesystem for bad sectors or other errors and hopefully fix them.
Then report back on what is revealed.
