Wayfarer Posted August 22, 2011 Report Share Posted August 22, 2011 Dear all,I've faced a strange problem in using the various web browsers. I use a Laptop with Windows 7 64 bit and I use ADSL internet connection. When I use my usual internet connection I don't have any problem, but when I use a VPN connection It is just the Google Chrome which is able to connect the internet and my other browsers i.e. Internet Explorer & Firefox could not access the internet. Also Yahoo messenger could not log in. As soon as I disconnect from VPN, the problem would wipe out. I use the Kaspersky Internet Security, But disabling this firewall & antivirus didn't made any changes.It is worth to say that I don't have any problem with this VPN connection on my PC with Windows XP 32 bit.Waiting for your comments. Quote Link to comment Share on other sites More sharing options...
Wayfarer Posted August 30, 2011 Author Report Share Posted August 30, 2011 Don't bother yourself anymore for solving this problem. I found it!I changed the DNS settings of my both connections i.e. ADSL and VPN to google DNS 8.8.8.8 and the problem was solved. Quote Link to comment Share on other sites More sharing options...
bludgard Posted August 30, 2011 Report Share Posted August 30, 2011 Don't bother yourself anymore for solving this problem. I found it!I changed the DNS settings of my both connections i.e. ADSL and VPN to google DNS 8.8.8.8 and the problem was solved.I had no idea one could do this.... Quote Link to comment Share on other sites More sharing options...
