karlmhc Posted January 19, 2012 Report Share Posted January 19, 2012 I have an issue with installing: Active Directory Management Gateway Service Windows Server 2003r2 SP2NET 3.5 SP1 also installed:NET 2.0 SP2 & .NET 3.0 SP2Windows Server 2003 SP2 Administration Tools PackWindows Support Tools I do NOT have the following installed:Active Directory Application Mode (ADAM) Here is the log (log file: KB968934.log) 0.157: 2012/01/19 15:09:33.637 (local)0.157: c:\57ae49f9eb7a655b0f32f538d975bf63\update\update.exe (version 6.3.19.0)0.157: Hotfix started with following command line: 0.157: In Function GetReleaseSet, line 1193, RegQueryValueEx failed with error 0x20.188: SYSTEM\CurrentControlSet\Control\ProductOptions\ProductType is Not Equal To Specified Value 0.188: SYSTEM\CurrentControlSet\Services\ADAM is not Present 0.188: Condition Check for Line 1 of PreRequisite returned FALSE 0.188: ReadStringFromInf: UpdSpGetLineText failed: 0xe00001020.188: KB968934 Setup encountered an error: Setup cannot continue because one or more prerequisites required to install KB968934 failed. For More details check the Log File c:\windows\KB968934.log0.188: ReadStringFromInf: UpdSpGetLineText failed: 0xe00001020.188: Setup cannot continue because one or more prerequisites required to install KB968934 failed. For More details check the Log File c:\windows\KB968934.log18.953: Message displayed to the user: Setup cannot continue because one or more prerequisites required to install KB968934 failed. For More details check the Log File c:\windows\KB968934.log18.953: User Input: OK18.953: Update.exe extended error code = 0xf0f418.953: Update.exe return code was masked to 0x643 for MSI custom action compliance. Tried locating KB968934 in the register, doesn't exist. Is ADAM not being installed the problem? the description of the patch is:"The Active Directory® Management Gateway Service enables administrators to manage Active Directory Domain Services and Active Directory Lightweight Directory Services (AD LDS) or Active Directory Application Mode (ADAM) using Active Directory module for Windows PowerShell and the Active Directory Administrative Center." Any ideas? Quote Link to comment Share on other sites More sharing options...
MANEMAN Posted January 20, 2012 Report Share Posted January 20, 2012 0.188: SYSTEM\CurrentControlSet\Services\ADAM is not Present Active Directory Domain Services (AD DS) or AD LDS server roles: you can install Active Directory Management Gateway Service only if you promote your server to domain controller by running Dcpromo.exe or if you create an AD LDS instance (or ADAM instance) on this server. I would guess that these are the "one or more prerequisites required to install KB968934" Just a guess mind. These (and other details) are available in the Microsoft download overview. For other more complex problems other than being able to understand the install instructions I would suggest heading over to Technet. John. Quote Link to comment Share on other sites More sharing options...
