Neff Posted February 7, 2012 Report Share Posted February 7, 2012 On my windows 7 lap top (right now I'm on my family computer) i decided to do a optional update because i was bored and i did it and it restarted like usual, but when i got back on my computer it became so slow i couldn't even click the start button without it freezing up and when i click on the browser nothing happens. The only way to use my lap top now is if i go onto safe mode. What happened? Quote Link to comment Share on other sites More sharing options...
bludgard Posted February 7, 2012 Report Share Posted February 7, 2012 Some updates can run the CPU up to15-20 minutes after restarting following the updates; thereby rendering the machine sluggish for a bit.If this seems like a permanent issue, have you tried System Restore to try to reach a state before the update?Can the update that seems to have caused or coincided with the unresposiveness be revealed? Perhaps a key will be found there.... :) Jobe Quote Link to comment Share on other sites More sharing options...
ɹəuəllıʍ ʇɐb Posted February 8, 2012 Report Share Posted February 8, 2012 Can you tell us which optional update you installed? If it was anything with .NET Framework, that can take hours of background assemblies after the basic install. Quote Link to comment Share on other sites More sharing options...
godflea Posted March 16, 2012 Report Share Posted March 16, 2012 What is the update including? Anything else installed? Quote Link to comment Share on other sites More sharing options...
