Herb Posted May 18, 2012 Report Share Posted May 18, 2012 System Restore appears to create Restore Points properly, but restoration always fails - never says why. (Shadow service never seems to work either) Is there a cure for the System Restore problem? Quote Link to comment Share on other sites More sharing options...
bludgard Posted May 18, 2012 Report Share Posted May 18, 2012 Possibly disabling your AV/AM (virus/malware program(s) will help. I have tested some (AV/AM software) that had to be completely removed before System Reserved could run successfully.It may also be worth looking into a more stable, reliable and comprehensive back-up regimen such as creating disk or system images of the hard drive or partition(s) thereon: This will ensure a safe return from the brink of total hardware destruction (possible by way of TNT [don't laugh; I've seen it]). :lol: Welcome, Herb.Jobe Quote Link to comment Share on other sites More sharing options...
ɹəuəllıʍ ʇɐb Posted May 19, 2012 Report Share Posted May 19, 2012 Can you explain how it fails? Anything in the Event Logs? Quote Link to comment Share on other sites More sharing options...
