01bloomj Posted July 31, 2012 Report Share Posted July 31, 2012 So I have had this problem for a while now and it's quite strange.I was having some computer issues and thought it was linked to a HDD problem.I was having blue screens and some quite serious crash dumps, Long story short it was a RAM issue and it was resolved by removing a module the module was not at fault because I switched around the modules and they all work but my system will only boot if RAM modules are in every other slot, this worked fantastically and the system was stable. But with less RAM that I wanted. So my question is, is there a deeper issue here or is there a fundermental issue with the Bus architecture? And therefore the system is on its way out.All my other hardware has been tested and I 100% believe that they are all working perfectly with no faults, in addition the RAM i am using is all the same and all used is DIMM 1333 2GB or 4GB sticks. Quote Link to comment Share on other sites More sharing options...
chrisjay Posted August 8, 2012 Report Share Posted August 8, 2012 Blue screens is not a RAM problem, this is problem with your Monitor or whatever you are using. Quote Link to comment Share on other sites More sharing options...
Alan2273 Posted August 9, 2012 Report Share Posted August 9, 2012 Blue screens is not a RAM problem, this is problem with your Monitor or whatever you are using.First time I have heard that.What motherboard are you using and is there a maximum RAM limit on it?. Quote Link to comment Share on other sites More sharing options...
ɹəuəllıʍ ʇɐb Posted August 10, 2012 Report Share Posted August 10, 2012 Blue screens is not a RAM problem, this is problem with your Monitor or whatever you are using.Sorry, but this is the most idiotic comment I have ever read in this forum! Quote Link to comment Share on other sites More sharing options...
