GYeates Posted August 22, 2012 Report Share Posted August 22, 2012 Hello,The office uses some important software (designed for xp) which runs poorly when the Aero setting "Use visual styles on windows and buttons" is enabled in system properties, performance options. I know you can use the "Disable window's composition option" to disable Aero whenever an application is started; however, a less crude fix would be preferred. Hopefully one that leaves Aero features unaffected for other windows.Any help would be appreciated! Thanks. Quote Link to comment Share on other sites More sharing options...
