Kougs Posted November 20, 2012 Report Share Posted November 20, 2012 Hi,I was using RDC the other day and I disconnected from the computer and a popup asked me if I was sure that I wanted to close the connect. I clicked "don't show this again" and I kinda regret it. Is there anyway I can get it to popup again? Quote Link to comment Share on other sites More sharing options...
MANEMAN Posted November 21, 2012 Report Share Posted November 21, 2012 Hi there. Welcome.If you are using a Windows operating system, I would suggest that you try first to do a System Restore back to a point in time before you clicked on the "Dont show this again" box.(System Restore is available on Windows ME, Windows XP, Windows Vista, Windows 7, and Windows 8. It is not available for Windows 2000)It is quite possible that by ticking the box and accepting the change, that a permanent deletion is made at registry level, and there may be no "Set dialog box to default" provision made for your particular operating system.John. Quote Link to comment Share on other sites More sharing options...
Kougs Posted December 3, 2012 Author Report Share Posted December 3, 2012 Thanks for the reply, but is there no other way to get it back? I've installed tons of programs since then and I wouldn't want to re-install them all just for a simply check mark :( Also I use Windows 7 Quote Link to comment Share on other sites More sharing options...
