rankinart Posted February 7, 2013 Report Share Posted February 7, 2013 Whenever I initiate a Works Spreadsheet or WordProcessing task I get the following "message": C:\PROGRA~1\COMMONS~1\MICROS~1\WORKSS~1\wkcalrem.exe I have to cancel the application, or whatever, to proceed.Apparently "wkcalrem.exe" is missing. I suspect it was removed in some past disk cleanup/defrag operation.How can I get " wkcalrem.exe" back, so I can use Works as I have before, for years?I'm not a techie, but I think the above "message" indicates the supposed location of "wkcalrem.exe". I also suspect it has to do with the Works Calendar (reminder?).JRANK1 Quote Link to comment Share on other sites More sharing options...
MANEMAN Posted February 7, 2013 Report Share Posted February 7, 2013 Hi.Try a few of the following suggestions:Make a System Restore Point before you begin.Backup your registry first, and then run the registry cleaner in CCleaner.( I even hate telling people to use this registry cleaner really. :( )Stop/Disable/Delete "wkcalrem.exe" - ( A Google search will soon show you how.)Perhaps: Use System Restore to reach a time when there was no problem.Perhaps: Reinstall Microsoft works. Quote Link to comment Share on other sites More sharing options...
