MANEMAN Posted February 24, 2013 Report Share Posted February 24, 2013 All hardware and software can be - "guilty" - of causing BSOD's until otherwise proved - "Innocent" - by means of analysis & diagnosis. A Microsoft MVP put together a whole list of tips, ideas and useful things to use when having to analyse a Bluescreen of Death ( BSOD )Credit: SpiritX .=.=.=.=.=.=.=.=.=.=.=.~ BSOD ~Tools that will help with analysis : Process Explorer - Free - Find out what files, registry keys and other objects processes have open,which DLLs they have loaded, and more. This uniquely powerful utility will even show you who ownseach process.http://technet.micro...s/bb896653.aspx Autoruns - Free - See what programs are configured to startup automatically when your system bootsand you login. Autoruns also shows you the full list of Registry and file locations where applications canconfigure auto-start settings.http://technet.micro...s/bb963902.aspxProcess Monitor - Free - Monitor file system, Registry, process, thread and DLL activity in real-time.http://technet.micro...s/bb896645.aspxThere are many excellent free tools at Sysinternalshttp://technet.micro...ls/default.aspx WhatsInStartUP - Free - This utility displays the list of all applications that are loaded automatically when Windows starts up. For each application, the following information is displayed: Startup Type (Registry/Startup Folder), Command -Line String, Product Name, File Version, Company Name,Location in the Registry or file system, and more. It allows you to easily disable or delete unwantedprograms that runs in your Windows startup. http://www.nirsoft.n...in_startup.htmlThere are many excellent free tools at NirSofthttp://www.nirsoft.n...tils/index.html Window Watcher - Free - Do you know what's running on your computer? Maybe not. The WindowWatcher tells all, reporting every window created by every running program, whether the windowis visible or not. http://www.karenware.../ptwinwatch.aspMany excellent free tools and an excellent newsletter at Karenwarehttp://www.karenware.com/ Consider this an absolute must - manually updating your drivers. This is my generic how to for proper driver updates :This utility makes it easy to see which versions are loaded :DriverView - Free - utility displays the list of all device drivers currently loaded on your system.For each driver in the list, additional useful information is displayed: load address of the driver,description, version, product name, company that created the driver, and more.http://www.nirsoft.n...driverview.html For Drivers check System Maker as fallbacks and Device Maker's which are the most current.Control Panel - Device Manager - Display Adapter - write down the make and complete modelof your video adapter - double click - Driver's tab - write down the version info. Now click UPdateDriver (this may not do anything as MS is far behind certifying drivers) - then Right Click -Uninstall - REBOOT this will refresh the driver stack. Repeat that for Network - Network Card (NIC), Wifi, Sound, Mouse and Keyboard if 3rd partywith their own software and drivers and any other major device drivers you have. Now go to System Maker's site (Dell, HP, Toshiba as examples) (as rollback) and then DeviceMaker's site (Realtek, Intel, Nvidia, ATI as examples) and get their latest versions. (Look forBIOS, Chipset and software updates at System Maker's site while there.) Download - SAVE - go to where you put them - Right Click - RUN AD ADMIN - REBOOT aftereach installation.Always check in Device Manager - Drivers tab to be sure the version you are installing actuallyshows up. This is because some drivers rollback before the latest is installed (sound driversparticularly do this) so install a driver - reboot - check to be sure it is installed and repeat asneeded. CONTINUED ON NEXT PAGE Quote Link to comment Share on other sites More sharing options...
MANEMAN Posted February 24, 2013 Author Report Share Posted February 24, 2013 Repeat at Device Makers - BTW at Device Makers DO NOT RUN THEIR SCANNER - checkmanually by model.Manually look at manufacturer's sites for drivers - and Device Maker's sites.http://pcsupport.about.com/od/driverssupport/ht/driverdlmfgr.htmInstalling and updating drivers in Windows 7/8 (updating drivers manually using the methods aboveis preferred to ensure the latest drivers from System maker and Device makers are found)http://www.sevenforums.com/tutorials/43216-installing-updating-drivers-7-a.htmlIf you update drivers manually then it is a good idea to disable Driver Installations in WindowsUpdates, this leaves Windows Updates ON however it will not install drivers which will usually beolder and cause issues. If Updates suggests a new driver then HIDE it (Right Click on it) and thengo look for new ones manually if you wish. ............................... Check with these utilities to see if any further information can be gathered :This is an excellent tool for gaining Blue Screen Error InformationBlueScreenView - Free - scans all your minidump files created during 'blue screen of death'crashes, and displays the information about all crashes in one table.http://www.nirsoft.net/utils/blue_screen_view.html MyEventViewer can be checked at the time of the BlueScreen (BSOD) to within a second orso of the time of the BSOD to provide more information as to possible cause - see TIP. MyEventViewer - Free - a simple alternative to the standard event viewer of Windows.TIP - Options - Advanced Filter allows you to see a time frame instead of the whole file -set it to a bit before and after the time of the BSOD.http://www.nirsoft.net/utils/my_event_viewer.html AppCrashView - Free - a small utility for Windows Vista and Windows 7 that displays thedetails of all application crashes occurred in your system. The crashes information is extractedfrom the .wer files created by the Windows Error Reporting (WER) component of the operating system every time that a crash is occurred. AppCrashView also allows you to easily save thecrashes list to text/csv/html/xml filehttp://www.nirsoft.net/utils/app_crash_view.html How to Run the Memory Diagnostics Tool in Windows 7http://www.sevenforums.com/tutorials/715-memory-diagnostics-tool.html Credit: SpiritX Microsoft MVP(and those to whom he linked.) Quote Link to comment Share on other sites More sharing options...
MANEMAN Posted March 1, 2013 Author Report Share Posted March 1, 2013 Another really good diagnostic tool is: SF Diagnostic Tool. You can read about it here: http://forums.windowsforum.org/index.php?showtopic=50535 John. Quote Link to comment Share on other sites More sharing options...
