JOHN007 Posted May 28, 2013 Report Share Posted May 28, 2013 Hi, There seems to a memory leak from svchost.exe which starts at 2300mb and exceeds over 3000mb on idle in 10mb stages,Ive own Vista so I turned off superfech as that takes up ram but still getting this memory leak? Ive gone through the Malware forums and they have stated that I should go here for further assistance. Thanks for taking the time read this, John Quote Link to comment Share on other sites More sharing options...
bludgard Posted May 29, 2013 Report Share Posted May 29, 2013 Hi, JOHN007.In my journeys through virtual interaction, the syptoms presented would indicate malware either past or present. The only thing I would suggest would be to recover the machine to factory default or format the HDD and reinstall Vista (optimally aqcuire a copy of Windows 7).Back up any files/folders that are dear and scan the hell out of them before migrating back to fresh install. Quote Link to comment Share on other sites More sharing options...
ɹəuəllıʍ ʇɐb Posted May 29, 2013 Report Share Posted May 29, 2013 You will need to investigate what is actually using that memory; svchost is - as the name implies - just the host for various services. Use Process Explorer to find out what service is using up your memory. Quote Link to comment Share on other sites More sharing options...
