Mattchew Posted May 28, 2013 Report Share Posted May 28, 2013 Hi, I am setting up a couple of dot-matrix printers - Oki's. When plugged in to Windows 8 the system sees a new device and runs through the install for that device, except the driver it installs is not the one we want to use. We need to change the driver which is fine, but when we unplug one printer and plug in another it assumes its a different printer and doesnt run using the same setup as before. Is there a way around this, so that we can create one printer on the computer with all the correct settings and driver and if it fails we can plug in the replacement and it works straight away without having to go through the install and changing the driver and settings all over again. Thanks Quote Link to comment Share on other sites More sharing options...
ɹəuəllıʍ ʇɐb Posted May 29, 2013 Report Share Posted May 29, 2013 Do these printers come with a manual? If so, is this the way the manual tells you to set up the printers? For printers, in 99% of all cases, the instructions are to install the drivers first, before connecting the physical device. Quote Link to comment Share on other sites More sharing options...
andsome Posted June 3, 2013 Report Share Posted June 3, 2013 Another ignorant person who cannot be bothered to return and let people know whether or not the problem is solved Quote Link to comment Share on other sites More sharing options...
