Farid Posted June 1, 2013 Report Share Posted June 1, 2013 Hi! I just install a new theme for windows 7 and it is called green HUD.Then after i uninstall it the icons still stay even i restarted my laptop is still becomes the default icon for the windows 7.PLS HELP ME!!!!Heres the pictures (DOWN HERE)file:///C:/Users/user/Pictures/123.PNG I REALL APPERICIATE WHO HELP ME!! AND BIG THANK YOU!! Quote Link to comment Share on other sites More sharing options...
Alan2273 Posted June 1, 2013 Report Share Posted June 1, 2013 Two points, you need to host the image as the shortcut is to your computer.Second have you tried a system restore to before you installed HUD. http://windows.microsoft.com/en-us/windows7/products/features/system-restore Quote Link to comment Share on other sites More sharing options...
Farid Posted June 1, 2013 Author Report Share Posted June 1, 2013 No i forget to restore those :( any ways to fix this? Quote Link to comment Share on other sites More sharing options...
Alan2273 Posted June 1, 2013 Report Share Posted June 1, 2013 If you have a W7 install disk you can do a repair install, this will leave your files and folders intact. http://www.sevenforums.com/tutorials/3413-repair-install.html If you do not have a full disk of Win 7, did you do a backup, if so you can use that to restore it to before you used HUB http://www.howtogeek.com/howto/1838/using-backup-and-restore-in-windows-7/ A third option is to rebuild the icon cache. http://www.intowindows.com/how-to-rebuild-icon-cache-in-windows-7-to-repair-icons/ There is nothing else I can think of. Quote Link to comment Share on other sites More sharing options...
Farid Posted June 1, 2013 Author Report Share Posted June 1, 2013 Thank you! Quote Link to comment Share on other sites More sharing options...
