MistaChocolate Posted September 3, 2013 Report Share Posted September 3, 2013 Well I've had pc for like almost 2 months which is windows 8 and I cleaned it with advanced system care and I rebooted and now it's stuck in a reboot loop . It's shows the Hp logo then screen turns black for 5 seconds then goes to like a messed up blue screen that makes it look like the display is broken. It does it over and over and I'm just so mad cause I'm only 14.. Can someone help ? Quote Link to comment Share on other sites More sharing options...
-pops- Posted September 3, 2013 Report Share Posted September 3, 2013 As it's only two months old you should be covered by the warranty. If that isn't possible, what backup/recovery disks do you have or is there a hidden partition with a recovery on it? Most HP machines have some sort of method of recovery. Quote Link to comment Share on other sites More sharing options...
MistaChocolate Posted September 3, 2013 Author Report Share Posted September 3, 2013 Well the problem is i don't know how to get in recovery mode cause in windows 7 you would hold F8 but you can't in Windows 8 Quote Link to comment Share on other sites More sharing options...
-pops- Posted September 3, 2013 Report Share Posted September 3, 2013 http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&lc=en&dlc=en&docname=c03489643 http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&lc=en&dlc=en&docname=c03483233 Quote Link to comment Share on other sites More sharing options...
MistaChocolate Posted September 3, 2013 Author Report Share Posted September 3, 2013 Well now it says "please install a new operating system" Quote Link to comment Share on other sites More sharing options...
ɹəuəllıʍ ʇɐb Posted September 4, 2013 Report Share Posted September 4, 2013 Looks like you have to reinstall Windows; did you read the links that -pops- posted. In the future, stay away from scam software like "advanced system care". Quote Link to comment Share on other sites More sharing options...
