laiho11 Posted September 15, 2013 Report Share Posted September 15, 2013 hi. i downloaded a few files about 10mb each using the run option instead of save. the download was completed but installation was stopped due to some problem. because i used the run option i do know that the file was downloaded in temp folder. but when i type in the name of the files i cannot find them in temp folder. The trouble is that there are many files that i downloaded using run but which could not be installed.i want to delete these downloaded files from temp folder as these unwanted files are occupying space. is there any way or do the files downloaded by clicking run get deleted automatically if their installation is cancelled. Please help Quote Link to comment Share on other sites More sharing options...
bludgard Posted September 15, 2013 Report Share Posted September 15, 2013 It may be best to Save the file(s) to a known directory before installing (running) the file(s). At least one will know where to look for the download(s).Try running CCleaner @ default settings and see if there is recovered space. Quote Link to comment Share on other sites More sharing options...
