wbunnell Posted May 2, 2014 Report Share Posted May 2, 2014 Why Can't you cut and paste on this forum????????? Quote Link to comment Share on other sites More sharing options...
Boris Posted May 2, 2014 Report Share Posted May 2, 2014 Why Can't you cut and paste on this forum????????? Not sure what you mean ? - I have just done this from your post above. What is your "wireless hidden file/folder" problem ? Quote Link to comment Share on other sites More sharing options...
wbunnell Posted May 2, 2014 Author Report Share Posted May 2, 2014 Not being very good at asking questions, I type the question with windows Word. After I think the question is explained enough, I use, right click, Select all, copy, when I try to paste it to this forum, there is no paste function highlighted. My problem is after I've used, my wireless, for months, the Icon in the lower right of the task bar shows yellow caution on the Icon.Rebooting solves the problem for a short time, then it shows the caution again.I guess there only a few times that caution shows up, now I'm getting a star shaped symbol on the icon. Highlighting the icon, it wants to connect to the wireless, when I try it gives me a message that says it can't connect to the hidden File.This better explained on a another Forum. The forum is Windows 7 Forum, under, "wireless Hidden files/folders."http://www.sevenforums.com/network-sharing/330230-wireless-hidden-files-folders.html Quote Link to comment Share on other sites More sharing options...
ɹəuəllıʍ ʇɐb Posted May 3, 2014 Report Share Posted May 3, 2014 Beside the standard Windows Paste (Ctrl+V) there are three additional ways to paste here in the forum:PastePaste as Plain TextPaste from Word(click on the icon above to see the image) Quote Link to comment Share on other sites More sharing options...
wbunnell Posted May 3, 2014 Author Report Share Posted May 3, 2014 Thank You! Ignorance is the most wonderful thing, sometimes I can't see the forest for the trees. Thank you again!! Quote Link to comment Share on other sites More sharing options...
Boris Posted May 3, 2014 Report Share Posted May 3, 2014 Looks to me as if you want to get rid of your existing wireless connection on that machine and set up a brand new one with the correct password ? Quote Link to comment Share on other sites More sharing options...
