moon Posted October 15, 2003 Report Share Posted October 15, 2003 A strange Thing happened today. Actually, strange Things tend to happen most days but this one highlighted a huge gap in my head. I switched on a machine and read 'Invalid System Disk' so I reached over to take out whatever was in there and....there wasn't anything. I tried rebooting several times, as this particular machine (98SE) has a stable history and no major changes recently. No luck, ' Invalid System Disk', so I popped in its Startup floppy, came to the A: prompt and then realised that I didn't have a clue as to what to do from there. Now I know that there's nothing seriously wrong with the machine, I just wanted to boot into Windows. How do you do that from the A: prompt ? Anyway, I tried inventing a few commands, A: Start A: Begin A:Windows? but just received the 'Bad Command name' message so I gave it a really bad command and stabbed the 'off' button. ( I don't know how to exit from DOS either) After a coffee, during which I gleaned a few clues from an old Manuel ( the ex pat Spaniard next door) I powered it up again and , lo, it booted to Windows. However, this is not just a ramble while I'm waiting for me tea. I really want to know what to do from the A: prompt using a floppy startup disk on a 98SE machine. Disgruntled.Tooting. Quote Link to comment Share on other sites More sharing options...
Chris Posted October 15, 2003 Report Share Posted October 15, 2003 I think you type:winor C:then, winThat it is."Invalid System Disk" - Could be a hard drive on its way out sign, the cable on its way out sign or just "one of those things"... Quote Link to comment Share on other sites More sharing options...
moon Posted October 15, 2003 Author Report Share Posted October 15, 2003 Thankyou, proweress, I'll give that a go in the morning. :) Quote Link to comment Share on other sites More sharing options...
monkeyhanger Posted October 15, 2003 Report Share Posted October 15, 2003 moonto load windows from a startup disk / dosInsert floppyturn machine onlet it boot to a:\type c: after the a:\ so it reads a:\ c: and then press enter.this should take you to c:\now type windows \ win after the c:\ so it says c:\ windows\win and enter.This should load windows.To exit from dos or the a:\ ( known as a prompt) give it a three finger salute; :P ctrl + alt + delete. Quote Link to comment Share on other sites More sharing options...
Chris Posted October 15, 2003 Report Share Posted October 15, 2003 You can actually type:Restart Quote Link to comment Share on other sites More sharing options...
monkeyhanger Posted October 15, 2003 Report Share Posted October 15, 2003 I always prefer giving finger salutes. Shows whose boss. :lol: The wife. :( Quote Link to comment Share on other sites More sharing options...
moon Posted October 15, 2003 Author Report Share Posted October 15, 2003 Cheers, chaps. :) Now that my interest is kindled, where can I find a list of Command Prompts to use from the Startup Floppy boot situation. Just simple and useful ones, I don't want to end up reading Mavis Beacon. :rolleyes: :D Quote Link to comment Share on other sites More sharing options...
djohn Posted October 15, 2003 Report Share Posted October 15, 2003 list of command prompts dos.Copy/paste the above into google and choose the fourth one down. It gives a complete list of all command prompt for DOS. j. Quote Link to comment Share on other sites More sharing options...
moon Posted October 15, 2003 Author Report Share Posted October 15, 2003 You mean ' Die autoexec.bat und config.sys ' ? :blink: Ja ? Quote Link to comment Share on other sites More sharing options...
Chris Posted October 15, 2003 Report Share Posted October 15, 2003 http://www.allcommands.com/index.php3?page...20commands.html Quote Link to comment Share on other sites More sharing options...
Guest nellie2 Posted October 15, 2003 Report Share Posted October 15, 2003 You mean ' Die autoexec.bat und config.sys ' ? :blink: Ja ?My mum used to say that to me when I was having a coughing fit!!!!'Die you bugger die' :o :o :o Do you think I was adopted????!!! (only joking mum!! :D )Err sorry off topic comment but I am in a wierd mood tonight... just ignore me and I might go away ! :offtopic: Quote Link to comment Share on other sites More sharing options...
moon Posted October 15, 2003 Author Report Share Posted October 15, 2003 Wise man say ' keep eye on woman in weird mood' :D Quote Link to comment Share on other sites More sharing options...
djohn Posted October 15, 2003 Report Share Posted October 15, 2003 Err! no. this is the fourth one down. I can't seem to make a direct link so copy/Paste this into your browser address bar. ;) http://www.allcommands.com/index.php3?page...20commands.html Quote Link to comment Share on other sites More sharing options...
djohn Posted October 15, 2003 Report Share Posted October 15, 2003 Strange, the link worked this time! :help: Quote Link to comment Share on other sites More sharing options...
moon Posted October 15, 2003 Author Report Share Posted October 15, 2003 Got that Djohn. Ta. Odd how my fourth one down on google is diff. to yours. One of those Things. :D Quote Link to comment Share on other sites More sharing options...
Guest nellie2 Posted October 17, 2003 Report Share Posted October 17, 2003 Is this solved now Moon??? Just trying to tidy things up a bit :D Quote Link to comment Share on other sites More sharing options...
Redhat Posted October 17, 2003 Report Share Posted October 17, 2003 If it int - check your wide/thin grey able thats going from your IDE port on your mobo to your HD, is in properly. Quote Link to comment Share on other sites More sharing options...
moon Posted October 17, 2003 Author Report Share Posted October 17, 2003 Yep, solved nellie. Next Weird Thing had better watch out ! :) Quote Link to comment Share on other sites More sharing options...
