pallascoffee Posted July 15, 2019 Report Share Posted July 15, 2019 I would like to secure my wireless network so that only the computers I want can have access to the internet and my network. How can I do that? sincerely, pallas Quote Link to comment Share on other sites More sharing options...
Boris Posted July 15, 2019 Report Share Posted July 15, 2019 Simply use a non-guessable wireless password or in your router settings, specify the MAC addresses of those you want to have connections and bar the rest. Quote Link to comment Share on other sites More sharing options...
ksanjeevp Posted July 18, 2019 Report Share Posted July 18, 2019 Enable ACL (Access Control List) with MAC. Quote Link to comment Share on other sites More sharing options...
RonPeters Posted August 27, 2019 Report Share Posted August 27, 2019 1)Open your router settings page. 2)Create a unique password on your router. 3)Change your Network's SSID name. Enable Network Encryption. 4)Filter MAC addresses. . 5)Reduce the Range of the Wireless Signal. 6)Upgrade your Router's firmware. 7)Use latest wifi standard. WPA 3 as of now Hope that helps! Quote Link to comment Share on other sites More sharing options...
pewpewmarc Posted May 29, 2022 Report Share Posted May 29, 2022 You can secure your wireless network by putting in a unique security password. Another thing is you can monitor who's connected on your wireless router by checking it on your Wifi's Admin Access, if you notice an unrecognized device then verify that if it is yours, and if it's not then ban that device from your Wi-Fi Quote Link to comment Share on other sites More sharing options...
