shekhar chavan Posted July 21, 2019 Report Share Posted July 21, 2019 The USB drive is an essential part of daily life for carrying data anywhere. The USB drive/SD card is so small that it can carry thousands of photos, music videos in your single small chip. what will you do if your USB flash drive /SD card gets corrupted? continue reading Quote Link to comment Share on other sites More sharing options...
-pops- Posted July 27, 2019 Report Share Posted July 27, 2019 This type of drive is so cheap it is folly not to retain a backup copy of all data on a second drive - or even a third if you're that concerned. Quote Link to comment Share on other sites More sharing options...
lokes Posted August 12, 2019 Report Share Posted August 12, 2019 1 Install Partition Master 2 Insert USB drive 3 Open Partition Master 4 Click USB Drive 5 Click USB option 5 Click Wipe Data 6 Click Create partition Quote Link to comment Share on other sites More sharing options...
RonPeters Posted August 14, 2019 Report Share Posted August 14, 2019 Insert the USB drive into the computer system through the USB port. Click on the “My computer- Removable disk icon. Then right-click the “Properties” tab to the Removable disk icon. Left-click the tools tab to select the button named “Rebuild” on it. Let the computer do the task of scanning and restoring files that were previously corrupt. Finally right- click the USB pen drive and click on eject to safely disconnect the drive from the computer system. Quote Link to comment Share on other sites More sharing options...
manisha Posted September 6, 2019 Report Share Posted September 6, 2019 On 7/21/2019 at 9:09 AM, shekhar chavan said: The USB drive is an essential part of daily life for carrying data anywhere. The USB drive/SD card is so small that it can carry thousands of photos, music videos in your single small chip. what will you do if your USB flash drive /SD card gets corrupted? continue reading What else anyone want if corrupted USB can be repaired. Quote Link to comment Share on other sites More sharing options...
alatwa Posted July 27, 2022 Report Share Posted July 27, 2022 1. Right-click Start icon. 2. Select Disk Management and click on it. 3. Right-click the corrupted USB drive and choose “Change Drive Letter and Paths…” 4. Click on the drive letter and click Change button. 5. Choose a different letter from the drop-down list and click OK. 6. Done Quote Link to comment Share on other sites More sharing options...
pewpewmarc Posted August 21, 2022 Report Share Posted August 21, 2022 a USB drive's easiest fix is to format it through windows file explorer. but if you have important data on it then... you're outta luck if it's totally corrupted. Sometimes I could be lucky by using the recuva software to try and recover files. Quote Link to comment Share on other sites More sharing options...
