chrisbird46uk Posted November 13, 2003 Report Share Posted November 13, 2003 Ive recently updated to windows xp. Since doing so ive had a lot of problems using the internet both through aol and internet explorer. When I load certain sites all that is displayed is a blank screen although it says 'done' at the bottom of the page. I use yahoo mail a lot and this loads up but it looks different to how it usually is, as if it isnt properly loaded up. Most of the buttons (send, delete, compose etc) do nothing when clicking on them. A friend of mine said this might be something to do with java or java script and maybe there's a setting somewhere I have to alter but I cant seem to find it. Can anyone help me? Quote Link to comment Share on other sites More sharing options...
chrisbird46uk Posted November 13, 2003 Author Report Share Posted November 13, 2003 I forgot to mention I also have problems when I use the search option from the start mention. The menu that did appear above the dog (what tyoe offile you want to search for etc) no longer appears and remains blank. This amkes me think its maybe a display problem with windows rather than just aol or IE? Quote Link to comment Share on other sites More sharing options...
Guest ellas Posted November 13, 2003 Report Share Posted November 13, 2003 any more info like graphics card,drivers etc. Quote Link to comment Share on other sites More sharing options...
Chris Posted November 13, 2003 Report Share Posted November 13, 2003 http://www.java.com/en/download/windows_automatic.jsp Quote Link to comment Share on other sites More sharing options...
Guest nellie2 Posted November 15, 2003 Report Share Posted November 15, 2003 chrisbird46uk.. welcome to the forum, some feedback would be nice. How are you getting on with your problem?? Quote Link to comment Share on other sites More sharing options...
