Fan Controller
Guest nellie2
Guest nellie2
Are you into modifying your PC... if you set your components inside the case to run faster then you really need to keep an eye on the build up of heat. The fan controller fits into a standard 5.25n dravive bay slot and allows you to adjust the speed of the fans inside your PC and monitor the temperature inside the case. It can also sound an alarm when a fan fails or when the temp rises above a set threshold!!!!
They look quite good too!!
fan controllers
Guest nellie2
I don't need to andsome...... my fan behaves itself. I thought it was blokes who liked things with lots of buttons and dials and twiddly bits... makes thier kit look complicated!! :D
I'll have you know that there's nothing complicated about my kit at all.
