Smarterair Posted April 26 Report Share Posted April 26 How often should I maintain my ducted air conditioning system, and How Does Ducted Air Conditioning Work? The answer depends on several factors, such as your location and climate. If you live in a mild or cool area where temperatures rarely drop below freezing, cleaning your AC unit once every two years would probably suffice. On the other hand, if you live in areas where temperatures regularly dip down into the 40s during the winter months, you'll want to consider cleaning your AC unit annually. Cleaning your ducted air conditioner is important because dirt and dust build up over time and can lead to mould growth inside your home. This causes problems like allergies, headaches, and even health risks. When you clean your AC unit, you can also remove dust particles from the vents. These particles enter the airflow through tiny cracks around the vent openings and become part of the indoor air. Cleaning your ducted air conditioning system is essential for keeping your home comfortable and safe. Follow these steps to ensure that your ducted air conditioning is maintained properly: Top 5 steps for how to maintain a ducted air conditioning system? 1) Drain water when necessary: Water that gets sucked out by your AC unit's compressor can cause damage to its internal parts. It is best to drain this water after each use. Some people prefer to empty their AC unit's reservoir manually instead of a drainage hose. Remember, though; it may be dangerous for young children to play with an open drain. So make sure there are no kids nearby before draining the water. Also, make sure your unit has been entirely drained before placing it back in service. 2) Check filters: Depending on the type of filter installed in your unit, they will need to be changed periodically (usually about every month). You can check the filters yourself by removing them and looking at the debris trapped within. If you notice any clogs, make sure to replace them immediately. Filters get dirty quickly, so it is essential to change them frequently. Always remember to keep your filters dry! If they become wet, they could break, which means that your entire air conditioning system will have to be replaced. 3) Change the oil: All AC units require regular maintenance because they run daily. However, most homeowners don't know that changing the oil in your unit is very important. Over time, the motor bearings get worn out and must be lubricated periodically to avoid premature failure. It is recommended that you change the oil every year. 4) Wipe off exterior surfaces: One way to prevent dust buildup on the exterior of your unit is to wipe it down with a damp rag at least once per week. Even though this step isn't required by law, it does help improve the appearance of your AC unit and make it more energy-efficient. 5) Perform routine inspections: Once a month, conduct a visual inspection of your unit. Look for leaks or damaged components. Replace anything that needs immediate attention. Ensure that your unit's electrical connections and circuit breakers are in good working order. A simple visual inspection should reveal any signs of wear and tear, and you can take care of those issues right away. If you are interested to learn more about Ducted Air Conditioning Work, feel free to contact us today! We offer a wide variety of services, including sales, service, repair, replacement, and installation. Quote Link to comment Share on other sites More sharing options...
Boris Posted April 26 Report Share Posted April 26 Found this quite interesting, even though being in the UK. Quote Link to comment Share on other sites More sharing options...
Johnn Posted April 27 Report Share Posted April 27 Now you are thinking to maintain ducted air conditioning system in best way. You need to make sure that your AC isn t leaking or vibrating too much. If there is something wrong with a duct, you can easily notice it. Quote Link to comment Share on other sites More sharing options...
