Battery question
Hurdy
I replaced my CMOS battery last month because I was getting Checksum errors and everything was OK.
Last night the PC crashed and when I rebooted I again got Checksum errors but I couldn't even re-enter the correct date and because it was late I decided to leave it until the morning.
This morning the PC would not even POST so I unplugged it and went off to purchase another battery.
I was mithering 'cos I was beginning to think new PSU etc.
However,when I replaced the battery it booted up fine - I went into the BIOS and entered my settings and it's been OK so far.
Has anybody ever experienced a PC not booting because of a failed battery?
And if the batteries are failing quickly is this a sign of a deeper problem?
TIA
Hurdy
Dud batteries are not uncommon. I bought three new timer/control batteries (same type as CMOS batteries) in succession for a camcorder before I had one that lasted for more than a week. The final one has been in now for four years.
It may well be then that your first replacement may have been a dud.
One thing you could check as well is that the CMOS "clear" jumpers are not in the reset position.
