Help! Recover the hard drive.
Have you tried the following ?
a) Connect the Ext H/D to another USB port on the PC
b) Connect the Ext H/D to another PC
If this doesn't fix it, see a possible solution at Method 1 here :- https://www.diskpart.com/articles/my-external-hard-drive-says-it-needs-to-be-formatted-7201.html#:~:text=▌Method 1.,-Use CHKDSK to&text=Step 2.,normal after restarting your computer
  • Like 1
I got the disc in RAW format.
I formatted the disc.
I scanned the disc with a recovery tool, but it sees only a small part of the data that was on the disc.
Is there any way to improve the result?
I managed to recover most of the files.
I came across this video on YouTube.
Hetman Partition Recovery was able to recover 90% of the data from the disc. This is probably the best result so far. Overall, I'm satisfied because I managed to recover most of the data for little money. Thank you all for your help)
