sc84 Posted February 10, 2004 Report Share Posted February 10, 2004 I'm having trouble getting AIM "aol instant messanger" running on my computer. During installation i noticed it skipped a file "C:\WINDOWS\SYSTEM\imagehlp.dll" then i recieved an error message having to do with several diff. files named "Glj7020" and Glj7075" etc. It installs, but when i click to open and sign in the program doesn't open at all? It's begging to become very frustrating, i've tried everything that i know might help, but no luck.-sal Quote Link to comment Share on other sites More sharing options...
spikeychris Posted February 10, 2004 Report Share Posted February 10, 2004 I don't use AIM so this is just generic advise. Have you un-installed and re-installed? You don't say what operating system your using, if Win98 XP then run SFC from run to replace the system files from disk. Quote Link to comment Share on other sites More sharing options...
Guest ellas Posted February 10, 2004 Report Share Posted February 10, 2004 says he is using windows me in his profile. Quote Link to comment Share on other sites More sharing options...
nellie2 Posted February 10, 2004 Report Share Posted February 10, 2004 I don't use AIM either but have found this for you.... you might find some useful info there, if not you can report your problemhttp://www.aol.ca/cgi-bin/aimcanada.cgi?ver=fromweb&plat=nl Quote Link to comment Share on other sites More sharing options...
