bvw Posted March 14, 2004 Report Share Posted March 14, 2004 You can remove it from your system completely, but I wouldn't worry about it.MSN messenger usually takes charge and runs Ok.If you want to remove the Windows Messenger I can give you a link which will remove it from your system, but after I did that I found I had a few hiccups and won't recommend doing it anymore. Quote Link to comment Share on other sites More sharing options...
bvw Posted March 14, 2004 Report Share Posted March 14, 2004 ps.....I've got both installed on here......no problems. Quote Link to comment Share on other sites More sharing options...
expertec Posted March 14, 2004 Report Share Posted March 14, 2004 It seems to be OK now, so I'll leave it alone. Quote Link to comment Share on other sites More sharing options...
