Problems with AVG updates?
nellie2
Are you having problems downloading AVG updates?? You may get more joy if you try a different download location.... I came accross this tip today which may help. :)
Go to C:\Program Files\Grisoft\AVG\6.0
Find the following file
url.ini
Right click it and click rename it.
Now open Notepad
(Go Start | Run Type in Notepad)
Copy and Paste the following into Notepad
[sERVER_NAME]
1=free.grisoft.cz
2=ftp.grisoft.com
3=www.grisoft.com
[sERVER_URL]
1=http://free.grisoft.cz/softw/60/fe
2=ftp.grisoft.com/pub/softw/60/fe/
3=http://www.grisoft.com/softw/60/fe/
Actual URL=3
Click File | Save As
Change Save as Type to All Types
Give the file the Name of url.ini
(note case)
Save the file in same folder that you changed the first file
(c:\Program Files\Grisoft\AVG\6.0)
Right click the AVG Icon in the System tray and click Exit
Now go to Start | Programs | AVG 6.0 for Windows | AVG Console to restart AVG
Double click to open the console,
Click Update Manager
You should now have THREE choices to choose from as your download site
