Agent Smith Posted April 26, 2004 Report Share Posted April 26, 2004 Besty, before I upload any files, I would like you to try something for me.Can you go to start, then run, and in the box type regedit and press ok.If an explorer type window opens, just close it and let me know. Do you know how to navigate and change things in the registry?Mr. M. Quote Link to comment Share on other sites More sharing options...
Agent Smith Posted April 26, 2004 Report Share Posted April 26, 2004 Besty, I have just checked the download from Marks link, and it is not what we want to fix your problem. (all it does, is prevent you from making changes to file extensions).However, after looking round the knowledgebase, it seems that 2k and Xp have the same registry key when it comes to default executable extensions, so I have exported my own key for you.Just save the attached file, and double click it, with any luck it should restore your programs to normal.Mr. M.fix.reg Quote Link to comment Share on other sites More sharing options...
Besty Posted April 30, 2004 Author Report Share Posted April 30, 2004 Thanks mr. m but the comp ended up gettin reformatted so am in the process of sortin everything out :( Quote Link to comment Share on other sites More sharing options...
