artist Posted April 26, 2004 Report Share Posted April 26, 2004 How to Wrestle Free from an Alligator1. If you are on land, try to get on the alligator’s back and put downward pressure on its neck. This will force its head and jaws down. 2. Cover the alligator’s eyes. This will usually make it more sedate. 3. If you are attacked, go for the eyes and nose. Use any weapon you have, or your fist. 4. If its jaws are closed on something you want to remove (for example, a limb), tap or punch it on the snout. Alligators often open their mouths when tapped lightly. They may drop whatever it is they have taken hold of, and back off. :huh: Quote Link to comment Share on other sites More sharing options...
lester1 Posted April 26, 2004 Report Share Posted April 26, 2004 2. Cover the alligator’s eyes. This will usually make it more sedate.Sounds like the missus :D Quote Link to comment Share on other sites More sharing options...
