rezbipul Posted May 11, 2004 Report Share Posted May 11, 2004 Dear viewers,I was wondering how to add an application like asus dvd player to system tray.Not programmatically but with the help of windows itselfIs there any way?(Windows ME)Thank you. Quote Link to comment Share on other sites More sharing options...
andsome Posted May 11, 2004 Report Share Posted May 11, 2004 WELCOME! to the forum. I have no doubt that one of our resident geniuses will help you before the day is out. Quote Link to comment Share on other sites More sharing options...
Boris Posted May 11, 2004 Report Share Posted May 11, 2004 If you mean that you want it to always auto-start with Windows ? Then put a short-cut to it in your startup folder.If you mean that you want it to be added to your Task Bar ? Create a short-cut to it on your desktop and then drag it onto your Quicklaunch bar.If anything else ?Please re-post Quote Link to comment Share on other sites More sharing options...
