Agent Smith Posted May 31, 2004 Report Share Posted May 31, 2004 There should be no need for you to play about with your mtu, not yet anyway. That will come later when you want to start tweaking things for maximum performance.You will need to be more specific when you say you are having trouble configuring the wireless connection. However, I suspect that it will have something to do with the SSID (Service Set Identifier). This is in effect an "identifying password" which your wireless connection will use to verify that it is talking to a device it is supposed to be talking to, and not just any old wireless device which happens to be in range.Check your documentation carefully Sir T, but you will need to make the SSID the same on the router and the card in your laptop, before they will be able to talk to each other.If the problem is not to do with the above, then let me know and I shall see what we can do.Mr. M. Quote Link to comment Share on other sites More sharing options...
Sir T Fireball Posted May 31, 2004 Author Report Share Posted May 31, 2004 Hi Mr M :P Not sure if this helps, but I just pinged the router/modem Ip and all 4 were received. Not sure where to look for the SSID thingy tho :ph34r: Quote Link to comment Share on other sites More sharing options...
Agent Smith Posted May 31, 2004 Report Share Posted May 31, 2004 Is the ip address on your laptop manually set, or assigned using DHCP from the router? Quote Link to comment Share on other sites More sharing options...
Sir T Fireball Posted May 31, 2004 Author Report Share Posted May 31, 2004 Would you care for another drink :unsure: :D Watchoo talkin bout Willis :PI had to configure the router/modem when I connected it to the desktop. Thats how I knew of the IP :D Quote Link to comment Share on other sites More sharing options...
Agent Smith Posted May 31, 2004 Report Share Posted May 31, 2004 I guess that means dhcp :lol: , but just to check, did you manually enter an IP Address into the connection details for your wireless card?Go to start, then run and type in cmd and press the enter key. At the command prompt type the followingipconfig /alland press return. You should get a whole host of figures, can you let me know what you get please.Also, the router will have an internal address, probably something like 192.168.1.1 or 192.168.0.1, I assume you have already connected to the router to set it up with your pc. What happens if you type the routers address into the browsers address bar on your laptop? Quote Link to comment Share on other sites More sharing options...
Sir T Fireball Posted June 1, 2004 Author Report Share Posted June 1, 2004 oops! Sorry for vanishing like that, but I lost all connection on both machines :rolleyes: Am gonna wipe both HD's tonight and start again. 1st time they have been formatted since bought, so probably no bad thing :D Will let you know how it goes and thanks for all your time and help people :) Quote Link to comment Share on other sites More sharing options...
