Installer.Trojan removed system files?
I got the installer.Trojan virus and before I removed it it corrupted and removed some system files. Namely, dll files. Also, rundll isnt running in the process window. AND I cant re-install windows because it ask for my original serial number which i thought I could find in my system info; the one I found did not work? Where do I find my original sn, and how can I make sure I have all my system files and programs-- theres so many. PLEASE HELP ME.
Notepad isnt working....WHY NOT? HACKERS WILL ALL DIE IN THE END I HATE YOU ALL!
Guest ellas
Magical Jelly Bean Keyfinder v1.41
The Magical Jelly Bean Keyfinder is a freeware utility that retrieves your Product Key (cd key) used to install windows from your registry. It has the options to copy the key to clipboard, save it to a text file, or print it for safekeeping. It works on Windows 95, 98, ME, NT4, 2000, XP, Server 2003, Office 97, and Office XP. This version is a quick update to make it work with Windows Server 2003.
http://www.magicaljellybean.com/keyfinder.shtml
