monkey Posted March 4, 2003 Report Share Posted March 4, 2003 how do you get a pic under your name i see every one has got one but me so will some body pls tell me tanks :( Link to comment Share on other sites More sharing options...
Guest ellas Posted March 4, 2003 Report Share Posted March 4, 2003 go to MY CONTROLS under the windowsforum banner and then edit avatar settings,post back if you have probs and if your really struggling tell me the 1 you want and I will put it in for you. Link to comment Share on other sites More sharing options...
monkey Posted March 4, 2003 Author Report Share Posted March 4, 2003 i still cant find it arrrrrrrrrr Link to comment Share on other sites More sharing options...
Guest Shirley_Crabtree Posted March 4, 2003 Report Share Posted March 4, 2003 As Ellas said click on My Controls under the banner and on the left side of the page there is a sub-section called Personal Profile.Just under there is "edit avatar settings",click that and you should be ok from there on. Link to comment Share on other sites More sharing options...
monkey Posted March 4, 2003 Author Report Share Posted March 4, 2003 thanks i got it all wrong but now i got i right :D Link to comment Share on other sites More sharing options...
mark2 Posted March 4, 2003 Report Share Posted March 4, 2003 Two steps Link to comment Share on other sites More sharing options...
mark2 Posted March 4, 2003 Report Share Posted March 4, 2003 then Link to comment Share on other sites More sharing options...
Prince of Calcutta Posted March 4, 2003 Report Share Posted March 4, 2003 love the artwork mark :D Link to comment Share on other sites More sharing options...
mark2 Posted March 4, 2003 Report Share Posted March 4, 2003 took too BL****y long tho :D :D sorted before I'd finished Link to comment Share on other sites More sharing options...
Prince of Calcutta Posted March 4, 2003 Report Share Posted March 4, 2003 put it as a tutorial! Link to comment Share on other sites More sharing options...
mark2 Posted March 4, 2003 Report Share Posted March 4, 2003 I can't do tutorials,sometimes I struggle to get my posts right :P Link to comment Share on other sites More sharing options...
monkey Posted March 4, 2003 Author Report Share Posted March 4, 2003 thank you can look this now if you want to that is :rolleyes: Link to comment Share on other sites More sharing options...
Guest ellas Posted March 4, 2003 Report Share Posted March 4, 2003 had a few bevys there mark2 :lol: Link to comment Share on other sites More sharing options...
mark2 Posted March 4, 2003 Report Share Posted March 4, 2003 twitchy after the 25 cups of coffee I've had today :D Link to comment Share on other sites More sharing options...
monkey Posted March 4, 2003 Author Report Share Posted March 4, 2003 you can lock this now :D if you want Link to comment Share on other sites More sharing options...
